Disc Adapter
mtl!zz
If you are talking about the A2Z dmuni disk adapter, which allows disks to be run
on non disk frames the wooly hat shop sell them for about £30, but if you look on xc
forums you can get them loads cheaper. I have one here in front of me that i bought last week
for £17 (Y)
Woo my 1000th post! :rockon:
yes, i'm talking about adapter that allows to put a disk on non disk frame.smt like woodman
The woodman one is rubbish as it is really expensive and you pretty much have to use a special woodman hub, the "A2Z Dm-uni" is what you probably need, but it only fits flat plate dropouts. http://www.mbuk.com/Kittestdetails.asp?id=487
They are pretty well made, good quality and they are not going to break.
If that dosent fit your frame, you could try a hope C2 with a special half caliper for non disk frames (these crop up on ebay occasionally) or get an engineer to make a mount.
how do you mean strech the dropout ?
Well presumably instead of having a hub between the dropouts, you now have
a hub and a piece of metal between the dropouts. I suppose it depends how tight your
dropouts are without being bolted up, mine are really tight on the hub.
Is it possible to put A 2 Z Rear Adaptor on a 06' zoo python frame?
and what does that flat style dropout mean?
If the chainstays are anything like the 05 python then, no it won't fit.
The part of the frame where the seatstays and the chainstays meet is to big.
This means the dropouts look like flat plates welded to the chainstay, your frame has them but they're to big.
Edited by bob87
