Rim Tar
adam trials
Yes they both sort of work, tar wont do that much of a good job in the winter weather, it'll just turn to oily mess, and hair spray doesn't last that long at all. So jump in and get a grind.
Sorted.
USE THE SEARCH!
having a bad day?
Edited by Scopse
Tar = noisey as hell in the dry, you can put too much on an the brake pad will stick, washes off in wet/muddy conditions.
Brake spray = pretty good, doesnt last very long, squeaks
Hair spray = dont even go there
Spray mount = (i have tried it) grabs like hell, but again pads can stick on!!!!!
Rim Grind = Noisey (varys depending on pads an severity of grind), works in all conditions, doesnt wear that quick.
Grind ***
Get a decent grind on your rim an some good pads, the softer the compound the shorter the pad life, and you will be good for anything.
hey man
i use tar and it sticks well if you but the write amount on i have had problems were my brake has stuck on but its not often just when i go over board with the stuff and the noise isn't that bad not to load but a very nice squeal
i used a grind for a bit but unless you have a good set of pads there isn't really any difference
hope this helps (Y)
Edited by rider_01
