How To Repair Crossovers On Maggie Hs33
sandi
You should buy a magura bleed kit with hose clamps. these are two blocks of plastic that hold the hose secure when put in a vice and prevents the hose from kinking or breaking. Then all you have to do is tap the barbed nipple into the hose. thats the only way i have been able to do it.
put the hose into a vice but dont tighten it up to much, then get a screwdriver and open up the end of the hose a little bit then just tap the barb into the hose with a mallet or hammer. if it wont go in then put a little bit of fairy liquid in the hose and around the barb. thats all you need to do mate, hope i have helped.
cheers lou.
