My Limey 320 Updated
josh barker
hi,
here are some pics of my limey which has now been updated. I would love to hear your views on my bike!!
and heres the problem that i use to have with it, the chainline was miles out with the 127.5 bb so i had to go down to a 118 bb which had solved the problem. (just advice to others who have posted topics about it)
spec:
Frame and Forks
- Frame: onza limey 320
- Forks: onza limey matching forks
Wheels
- Front hub: echo tr disc
- Rear hub: onza t-master
- Tensioner: onza intergrated
- Front rim: try all front 20" silver
- Rear rim: try all rear 19" silver
- Spokes: mutiny black
- Rim tape: try all xxl
- Inner tube (front): maxxis welterweight
- Inner tube (rear): kenda
- Front tyre: Try-All
- Rear tyre: Monty
Brakes
- Front brake: Magura Louise
- Rotor: rockman rotor 160mm
- Rear brake: magura hs33 4 finger blade
-pads: tnn cnc backings with try all red croco's material
Drivetrain
- Cranks: trialtech 165mm
- Freewheel: tensile 96
- Chain: kmc kool chain
- Pedals: dmr v8's
- Bottom bracket: FSA platinum 68x118
- Bash: echo lite
Steering
- Headset: onza mongo
- Stem: onza t-master
- Grips: trialtech foam
- Handlebars: try all 09 rage
Edited by josh barker
Nice, handy to know about the bb thing, I think if I had a shorter bb on my skull, my cranks would hit the frame/I'd catch my foot on the maggie but I'm gonna have a squint.
Edit: I'm talking bollox, it'll be fine
i was panacking about the bb length but i have about 6-8mm clearance (approx havnt measured) with trialtech cranks
does your chain slap on the chain stay ????
i need to no what set up to use as im getting a limey soon .
and is your bb shorter than the tryall 122.5 ??
and how close is your freewheel to the bb shell ?
let me no asap
no the chain doesnt slap on the chainstays it slaps a bit on the seat stay when the chain gets a bit slack
the bb i use is a fsa platinum 118mm and the freewheel is pretty close but not close enough to cause disruption
cheers mate :)
do you think the tryall 165mm cranks would fit if i had the fsa bb . like would they catch on the frame or would i need a bashring on too ?
sorry to bore you with these questions but i have to no .
i havnt had a straight answer . and you have one built up so ypu looked a good guy to ask .
chris
cheers mate :)
chris
try all cranks will go on easily i run 165 trialtech cranks you may need a bashring or spaces, i have been told the sprocket on the rear hub also has a part in this to depending on where abouts it is (closer or further away from the frame, i tried turning the sprocket round but when i got the bb i just turned the sprocket back around to the normal position then it was better)
cheers mate thats a really good help
thanks alot :)
Run a thiner chain seeing as your set-up is that close to the chainstay.
Your using the KMC Kool 1/8'' chain, right?
Just buy the KMC Kool 3/32'' chain - it'll give you a few mm extra clearance..
yeh i run the kmc 1/8" chain but it seems to be sorted now but i will keep that in mind cheers!
Looking sweeeet mate , when i start riding again we will have to have a ride.
deffo Nick, would love to have a ride soon mate
Nice bike :) If you want to sort out the chain line once and for all, use a 113mm BB (I use a Truvativ ISIS BMX specific). Works perfectly on my Limey 320.
what rear rim and cranks you using, i think my freewheel would rub on my bb cup :S
but my chainline is already sorted now, but when i need a new chain i am going for a thinner chain
