Which Trials Bike?
bikemad786
well as i caint find my last thread i might aswell make a new one i have been offered a monty x-hydra for £275 second hand with maguara hs33's and its the old model with steel frame
but i also seen these http://www.bikes2udirect.com/B1337.html?id=BGHW8Vmc
http://www.bikes4trials.com/products.php?p...1p315&i=309 is there any difference in weight between the two?
well i have just realised that the 20" bikes have different handle bars to the 26" witch are like mtb bars would it not be hard to ride the 20" also would i be right size for the 26" im 5ft 5" im just wondering as i might want to drive to the park were a few other people ride trials there
I wouldn't touch the Saracen with a ten foot pole. The Da Bomb has a waaaay better spec, especially as it has Maggie HS33s. If the Saracen is anything like my old bike, it will fall apart in a matter of minutes. But I don't think there is much difference in weight, if the frame is made from the same aluminium then usually its around the same weight. :blink:
And unless I have read the post wrong, the first bike is made of steel. You'll yank your arms off trying to bunny hop, then again do anything, on that thing.
Another suggestion is to look at Onza bikes. If your just starting, they are great. Some of them come in around your price range. I gots myself an Onza T-Pro.
Hope this helps!
Beans :turned:
yup it does help but the saracen is not made out of steel? :S
Sorry bit of a grammatical error I just realised. I meant the bike that you have been offered, the Monty X- Hydra. Steel will be stronger, but it is not worth the weight if you are only just starting. Aluminium is still very strong, but a quite lot lighter.
Sorry for the misunderstanding!
Beans :turned:
