Freewheel
Tom J
i have just bought snail cams and i have the same problem as last time one part of my chain is tight and you spin the freewheel its loose does anybody know how to fix or stop it i have tried making the chain tight where its loose you spin the freewheel and its really tight and that must be bad!
its like that even on the slackest setting on the cam? :blink:
JK
If its what i imagine, then its a corse of both the cranks and the freewheel. Which ever cranks forward you are, the chain tends to be tighter and the opposite when your bad foot is forward. This is only due to the drive system bedding in, which is nothing to worry about as all fornt freewheel systems do this, hope i helped.
cheers
nathan
Edited by chocolate_bikes
The reason your tension is tight then loose is that your freewheel is never exactly central on your cranks and your cranks are never exactly central on your BB. There isn't a lot you can do apart from buying CNCed cranks and even then the sprocket on your hub won't be exactly right.
Tom, its fine, dont worry. Use some of my cooking oil. lol
If you wanna get validated, put your punctuation in, you write one long sentence that is like 5 lines long.
Also try to put your capital letters in. :D
sorry for nagging!
Crum...
sorry for nagging!
Crum...
Cooking oil only doe's the chain lol
I will keep that in mind!
How the heck will cnc cranks help. The most likely reason your having this problem is that your bottom bracket is bent slightly. Its a pritty comman thing to happen to squared tapered bb's
