Wheel Building?
Ticker
Hi i just wondered if anyone could help me.
I am looking for a website or somewhere that gives you a step by step guide on how to build a wheel.
I have a old wheel that i want to try and learn on, and then hopefully build a new wheel up.
Thanks Ticker.
OBM's guide is pretty good..
WHEEL BUILDING
Thanks a lot i've just had a quick read I hope its as easy as he says it is.
I will have a go with my old wheel when i get home from school.
My wheel is a 32 hole i think it wants to be three cross does this make a lot of difference to how you lace it up i.e how many spaces you leave between each spoke? cheers.
Edited by Ticker
Most wheels are 3 cross - the only difference is in the spoke length. Also, make sure you have the right length spokes to start with unless you just give it a go and see.
Jamie
I used OnzaBoyMarks guide...Before you de-build the wheel your going to be using...Check how many spokes it crosses over before it goes into the hole...That way you will know how many crosses to build it.
I built my first ever wheel last night...It's not as hard as i thought it's actually piss easy if you've got patience.
My result was this :):
Thats a 3 cross build. 32 hole.
Just remember when tensioning...do the same amount of turns on each spoke till it eventually gets tight...Just keep going round say doing 3 full turns on each.
Good luck. Any problems PM me.
Danny.
Edited by Danny Kearns
Well done pal
new rim will be needed for me soon and i fancy a lighter rear hub so now i know where to come to get my wheel built!
Harry!
Bet u get a paul one or summat haha, i used that OBM tutorial helped alot found the sheldon brown waay to complex :S.
Matx
