Would I Kill A Onza T Pro 07
Dave Anscombe
so muel........keep the kones tight and pack the rear hub full of grease?
does the t pro have snail cam bolts?
Yea make sure you do otherwise they wobble alllll over the shop.
Yes it does. no cams or bolts in it as standard though.
It uses chain tugs, i dont think theres any holes for snail cam bolts you could drill your own though. But onza dont use tiny little dropouts like gayboy deng so you might not get enough adjustment with snailcams. Tpros ride amazing at what ever level your at.
zhicycle
personaly i would chose this zhi instead of the t-pro, its only £100 more than the t-pro and the spec is a suprisinly good.
it comes with zhi drilled rims zhi cranks decent bar and stem v brakes (could upgrade to better pads) sealed bearing hubs. full spec is in the link.
Toby (Y)
Edit: picc vvvvvvvvv
Edited by TOBY-E
the problem at the moment with onza is, you'd have to upgrade to a t-comp as alot of dealers have run out of T-Pro, aire valley had 10 or 15, before xmas and there all sold out (goes to show the product sells well) i think the spec on the cranks and freewheel are the main thing.
The frame as has been before it is pretty much the old levelboss which has been a bench mark frame in the onza line and has been and still IS the most popular trials bike choice.
Upgrade to a t-comp and benefit from the magura's, drilled rims etc. OR push the boat out and get an extremly silly specced t-pro at £750 and it BLOWS other bikes away.
Wayne.
