Middleburn Rs7's
sjc59
Hi when i got my bike back from the person who brought it from me they had replaced my old 3-piece cranks with some nice middleburn rs7's with the trials bash guard I've had a look but not sure how this attaches to the cranks can anyone shed any light?
The bashguard (or spider, onto which the bashguard is mounted) has an internal saw tooth type shape which slides onto a matching form on the cranks, and a lockring holds it on. Middleburn call this rounded saw tooth shape the "Sweet torque" spline pattern.
In the PDF below you can see a step-by-step guide that I wrote to removing the bashguard, with plenty of photos. This should more than answer your questions I hope, including tools required and the method.
http://www.heatsinkbikes.com/content/Bashguard/bashguide.pdf
Steve
Hi there,
Your local bike shop should have the tool because it's the same pattern as a shimano item used on older cranks before 2pc and even before octalink. If you're mates with them pop in and I'm sure they'll lend it you or hook you up.
peace
Vice and a hammer will get the lock ring off, and it wont damage it if your carefull. Bit of WD40 helps to :).
Quite right, there's no reason why you can't tap the lockring off with a hammer and punch whilst holding your crank arm in a vice with a cloth wrapped round it. Just be careful, it's easy enough.
