Cranks
Josh PWND
170mm if you're weak or still in the TGS era, 160mm if you've got an explosive style, that's the way I see it. Personally I far prefer 160's to 170's, currently running short cranks on my stock and they're so much better than long ones. There's more to the choice than how they interfere with your cornering abilities at high speeds :P
Edited by Inur
Its all down to your riding style really. Also how tall you are and what kind of build.
Smaller cranks mean that you can perform rotations quicker (but so can gear ratios).
Longer cranks mean more leverage (torque) so you may be able to put more power into things.
BB's on most trials bikes seem to be quite high now, I can't see hitting the floor being a big problem unless you like to pretend your a speedway rider :P
