Removing Cranks
!laycky!
too start off with sorry about the title didnt no what to call it.
right every time i have taped cranks they get stuck on the bb and the only way i can get them off, is by cuting the bb off and hitting what is left off the bb (inside the crank) off with a peace of metal and hammer till it cames out.
now should i buy isis bb and crank or just buy bb and cut off my off cranks?
also what the difference between them other than price
cheers laky
Edited by !laycky!
cheers laky
OR buy a crank extractor?
Skoze
cheers more help than sidehop
but still would like to no the difference
Cheers :P
Do you want to know what the difference is between a crank extractor and just beasting it off with a hacksaw and a hammer? or something else?
Crank extractor:
easy to use tool, removes the crank arm with a relatively small amount of effort
saves you money as you dont end up damaging your parts
Beasting it, (also known as the "give it beans" method)
In your way, you cut the bb up, so need a new axle,
Hammer can damage cranks,
Just alot of effort really.
EDIT: just realised the original question.
Square taper round off easier, thus making crank/bb useless if that happens.
Isis are far harder to round off, as they have alot of sticky outy bits (technical term i know..)
Isis cranks just tend to come off easier.
Matt
Edited by Skoze
All you need is a crank extractor. and because you have square taper you dont need nothing fancy. A LBS would sell you one.
what i ment was you said it as if everyone should know that, i have only really got in to trials and bike for that matter, so maybe you could be a bit more help full next time.
This topic is now closed to further replies.
