Nooobie!
onzatrip
hi im quite new to trials been doin it for a month now and im wandering if my parts on my bike are good engough. when i see new people on here thay have echos, onza t-pros zoo etc my spec on my bike is:
frame: onza t-bird
forks : stock onza ones
cranks: onza with square taper bootom braket
wheels : stock on the front and stock with a try all hub on the rear
bars: echo
stem onza t-master
brakes: front vee and rear magura
i can pedal hop side hop and started to gap will i need better parts like front free wheel does that make a differnce?
cheers
tris
frame: onza t-bird
bars: echo
stem onza t-master
Definatly replace the T-Bird cranks! There so unreliable with the chainrings bending and snapping.
Also a T-Pro frame and perhaps Echo Lite forks would make life easier for you when learning.
But getting 'good' parts doesn't mean you'll be a better rider, it'll only make things easier.
