Adamant Freehub Bearings..
JoeM
The bearing number is 6903RS. I tried googleing it and nothing came up.
Well I found loads, even the 1st ones on google are the correct bearing.
The numbers specify different properties of the bearing, so the 6903RS means.
Single row deep groove, very thin section, 17 mm bore then the RS stands for single rubber seal.
Edit: Looked for some double seal on ebay and found these , should be the correct one if the number you gave is correct.
Edited by ZeroMatt
