Magellan Tucana
Alex Dark
The yellow one is the tucana PRO and the other is the STD.
PRO has long and short versions
Long is 1090mm
Short is 1075mm
+30mm bb rise
380mm chainstays minimum
Tyre clearance is ok for 2.5 inch
Weighs 1.9kg
Some other bits that I can't make sense of are random measurements of 172mm and 408mm. Also unsure if it's mod or normal spacing.
Only one version of the STD is made
1065mm
+15mm bb rise
385mm chainstays
Weighs 1.930kg
Only one random measurement on this one and I'm guessing its for the 10mm v bosses.
This is for the 08 models.
Edited by ZeroMatt
Alex you should get a Marino.
Tucanas seem to be the staple frame for mid-range Eastern European riders.
marino? never heard of it...linky? after some searching i came across this.... http://www.trials-forum.co.uk/forum/index....2&hl=marino
to say it doesnt look good is an understatement... nick?
Yep magellan are definitely hungarian..i know that much
Edited by Alex Dark
ive used the 04,05,06 models and if it wasent for an offer on the zhi continued with the 07 ..none of the frames broke they are made from 7005 . in hungary one of the top rider broke his coustellier v2 in 3 mounths and now is sponsored by magellan and for the 2008 season he will desigh the frame...so if y whant a good frame and low price go for it
