Sponge
In theory cutting threads would be fine yeah?
Unfortunately not... as Ali said, you need the two 5mm allen key fittings to get the hub apart and there's not enough meat in the axle to allow you to tap a thread in.
Much easier to readjust and refit a QR wheel if it does move - A friend of mine has his bolted wheel come loose regularly when he comes up short on gaps and lands on the bashguard/crank. If he hasn't an allen key handy that's his ride over...
You can replace QR's with anti-theft bolts (They go the full way through the hub like the skewer). Only get the ones with 5mm allen key heads - there a quite a lot of 4mm ones around and they never do up tight enough...
