Koxx Brown Cnc Backings Help
TrAsHeR
So I took the material out of the plastic backings and then cutted a bit off the each sides.
Then pushed it in, put some superglue on the side and then in a vice.
And when I took it out of the vice the middle of the material just popped back out.
What should I do?
Cheers
Hi!
It's always a good idea to do a test fit without glue so that you can check the pad inserts properly before getting messy. If it needs a bit trimmed off when you have glue in there, then it means a bit for work as you will have to cut away some dried glue aswell to get the pads to fit in properly. It's perfectly salvageable from where you are at the moment though.
Another good idea is to take the opportunity to square the braking surfaces of the pads off before you get to work, although this does require care if you're not doing it all the time. I use an sander turned upside down and have taken the skin off my hands enough times to have worked out how to do it safely!
I should have mentioned in my last message that I don't mind doing this fitting for you if it helps. I've noticed that my "How to" guide could do with some more details to make it a solid guide, so it would be useful for me aswell to do a fitting and get some photos & guide text sorted.
Steve
Hi!
Steve
So they should stay in correctly if you push them in without glue.
And thanks again for you help.
What glue did you use 1st time round? when I got some coust material just popped them into plastic backing (with a bit of drilling :S) I used the thin super glue. Not the one with 2 cylinders
At both attempts I used some cheap super glue.
And yeah all I had to is cut half a mil on each side and the it went in perfect.
I am pretty sure they will stay in there without any glue.
  • 2 weeks later...
Well I know koxx brown are amazingly good.
I have now tried them for a few hours of riding on a shit grind and I have to say the hold is pretty.
As I have a booster I really don't get much noise, which I am happy with.
And no, if you have a decent sharp grind I really wouldn't recommend tar as they work very well.
So yeah Sharp Grind + Koxx boxx in cnc backing = Crazy good
