Monty Quad Disk Brake + Hope
gu trials
I have a monty quad disk brake which is made for a 160mm rotor and i also have a hope adapter 20+ to make it fit a 180mm rotor will this work ?
and i also need 2 know where you can get these brakes from and spare parts for them.
thanks
matty
Edited by gu trials
raleigh are the uk distributor for quad brakes, give them a try
http://www.raleigh.co.uk/contact.aspx
regards to the adaptor is it a +20 adaptor like this one:
http://www.cambriabike.com/shopexd.asp?id=...RK%20ADAPTER%20
if so it will work but you're better off using a proper 185 postmount to is adaptor the will replace the bracket you've got with your calliper at the moment. If you need a 185 adaptor and a rotor i have both for sale.
feel free to pm if your interested
craig
Edited by craigjames
