Grrrrrr
Synergy
got it out.
what i did was undid the one bolt which would unscrew. i then got a b.m.h (big mouther f**ker hammer) and got a screw driver and started hitting the other boltuntil it would come out.
guna order new snail cams as the expensive try all ones are shit. also a new bolt me thinks. jsut got to file down the rough bits on frame and put a new snail cam bolt in.
Edited by Synergy
tighten the bolt fully that you got out, then undo the stiff side, then take the easy one out ?
tried that when i fully tighten the other side it will turn the axle too with the other bolt. when it is fully tigthend and i try undo the stiff one it undoes the one i jsut tightend if that makes sense?
