Vee Pads.
Ladd
Rite, Getting myself some CNC Plazmatic Vee Backings, And need some material for them, will material straight out off magura pads fit into the backings like normal vee compound?
If you have 3 pads then you can cut up the 3rd and use it to fill the gaps at both ends.
Alternatively, I'd recommend using Epoxy resin to fill the voids.
Steve
How can you modify them? the plaz backings are longer than maggie ones?
