How To Fit A 1/8" Chain Through A Rear Mech?
greenmeansgo
I've just put a bmx chain on my bike to complete a single speed set up, and I want to use my rear mech to tension the chain. Chain is a KMC Kool 710, and the rear mech is Shimano STX. All very nice, the chain line is ok, but the master link won't run through the mech.
I've bent the cage out a bit around the jockey wheels by removing the jockey wheels then using pliers, but the section between the two jockey wheels is a right git to bend and this is where it still catches.
Has anyone already successfully done what I'm trying to do? Any tips on how to do this without breaking things would be great.
PS: I've already tried to just "man up" and do it, so any other suggestions?
I've also got a kmc 710 on a rear mech. As said already, you could put washers either side of the jockey wheel, but however i just removed one of the cages, then used a bolt to tighten it up. Seems fine, nothing has bent yet, and it saves some weight!
Genius.
Master link as in the split link?
You could take that link out.
Yeah, probably also called that. I mean the link that comes separate to the chain when you buy it. It has one outer link plate with two pins, one outer plate that slides over the other end of those two pins and a clip that holds the second plate to the pins.
Isn't this link supposed to be a stronger way to make the chain than pushing a normal pin out and back in again with a chain tool? I'd rather use that link and modify the rear mech I think.
Anyway, thanks to everyone for the help and ideas (Y)
Its weaker! As the 'split-link' has thinner shaped plates, so more prone to snapping...
After all, a chains only as strong as its weakest link - so I'd just push the pin back through :)
Hmm.
I definitely agree with your logic, but I'm sure I read something by Sheldon Brown along the lines of pushing the pin out and back in weakens the join because it's no longer as tight a fit as it was from the factory. And so you should use the split-link that comes with the chain (at least that's how I remember it). I also thought the thinking behind them was for people who like to remove their chain regularly to clean it, so they don't have to break links all the time (I don't come under this category).
Other thing is I've shortened the chain to get good tension, so if I wanted to use a standard link and push the pin back, I'd have to either shorten the chain by one link (doubt I'll get away with that), or replace the split-link with a standard link (which means the chain will contain two pins that have been pushed out and back in again, which is surely worse than only containing one).
So what's the consensus on split-link strength/ what I should do? Confused now :huh:
Now what's the deal with the special split-link? To use or not to use? Advice/ wisdom would be gratefully received!
Would that being a joining link that snaps in place rather than the standard one with a circlip?
I found no master link is the way to go, when I used the one with the clip it managed to fall off my chain (which is a nice thought to be riding around with a link that can fall out at anytime).
And snap links where you have a plate with 2 holes and a plate with 2 pins on I have found to be just as bad, having snapped some myself (and I'm not exactly a beast of a rider), I don't like this idea as due to the design it is the link in the chain that gets the most stress.
Just rejoin the chain and you should be fine. =D
