Snail Cams
SkiLLz
Every time I get chain tugs for my bike they don't fit so they end up snapping so I'm going to get some snail cams instead but I've never used them or seen them on a bike before. How do I set them and which is pair to buy?
you'll need to mae sure your frame has some little threaded holes just infront of the dropouts so you can screw the bolts in for the cams to push against, otherwise you'll need to get the drill out and a set of taps (M5x1mm) and do it yourself. I strongly recomend the zhi snail cams, they do the job nicely and are chunky enough to take a fair bit of force, unlike the monty ones.
