Brake Hose Diconnected Help Asap
Mtchell
yerp ive got anew olive but when i place it on the hose and reconnect it bleed it and set it back up ,under the pressure it pops back off again,
its driving m insane ,
i got the olives with a magura brake service/bleed kit from tartybikes the olives seem slighty bigger than the 1 which was on the hose to start with ive read on google something about crimping???
Edited by New2it
you need to tighten the bolt up more so it properly crimps the olive on. First though cut off about 1cm from the end of the hose, incase there is any damage causing the olive not to sit properly.
orite easy as that asif ,cheeers mate (Y)
if it is still not working post some pics so we can see what the problem is. Are you using the correct hosing.
DONE :D nice 1 mate ,rebled worked well till i went flying off the thing and ive gone and snapped the lever connection pin which pushes the lever piston down :(
BUT my faithful riding partner has managed to find me a new lever in the loft woop woop
Thanks for your time and help !!1 (Y)
