Eno Freewheel.
TrAsHeR
Right I am used to servicing eno's .
Just bought a new one which I have serviced and now trying to put back together.
I have been trying for the last 3 days to put it back together which is driving me mad.
And bent two springs which so then bought two more.
So took it all apart and tried fitting the bearing on the body.
Which wont go.
Is the diameter of the bearing too small?
Or what am I doing wrong?
Thanks for the help.
Edited by TrAsHeR
I reckon your just not trying hard enough.
But as you say your not noob to the whole process then it can't be anything your doing wrong. The parts are made to a high standard so i'm just going to go with bearing deformation.
I've never actually serviced my Eno but will be doing so when i get my hands on a vice. Life is surprisingly hard without one!
So yeah i'm real hazy on this. But i'd inspect the bearing as much as possible.
You were right I wasn't trying hard enought.
Got the hammer out and it worked without any damage.
But they usually slip in with hand power.
Cheers for you help
