Onza Blade Or 08 T Comp?
L Plate
Well, The '08 Comp retails at the same price unless some shops are dis counting last years models.
You have 3 things to decide, The '08 Comp does have a front HS33 but the Blade bare the highly reputable Dual pull disc. You get a side drilled hog rim on the Blade and a rear disc mount if you decide to go double D later on. Otherwise they are very similar in spec.
im thinking maybe Blade ...
