sobek Posted January 2, 2009 Report Share Posted January 2, 2009 Hi all. Not sure if this have been a topic before...did a quick search but found nothing.Im currently running echo cnc brakes on the rear wheel and as of late i found them to be...crappy. often doesnt hold and have to pull the lever...often until its touching the bar.thought it might just be because its cold but then found it to be that the fluid is leaking.does anyone know if this is repairable or should i send them back to echo for the warranty?thanks all. Quote Link to comment Share on other sites More sharing options...
Greetings Posted January 2, 2009 Report Share Posted January 2, 2009 You'd best send it back for warranty since this can't be fixed. Quote Link to comment Share on other sites More sharing options...
