Help!
Jamie_Trials
i bought the kenda innertube off tarty, as mine bust >_<
my tyre wont stay inside the rim and just bulges out in the same place every 5 mins i blow it up!
i know thats because of me getting screwdrivers, spanners e.c.t but does anybody know how to reform the tyre?
P.S its already in the vice trying to reshape it :giggle:
Edited by Jamie_Trials
1. When blowing up the tyre blow it up slowly.
2. When blowing up, pull the back end up off the ground so that the tyre does not get any bulges.
Try that mate should work :D
there's a little problem
Ive tried that 7 times today :giggle:
but used a car pump so il give it a doing it slow go tomorrow morning
Volume is the ammount of air in litres that is going into the tyre per minute. Obviously a car pump (I presume you mean an electric compressor) is designed to pump the car tyre up fast (high volume, low pressure). Your average track pump is a lower volume, longer stroke, and designed for higher pressures (designed for pumping up road bike tyres), and a small hand held pump is very low volume and short stroke.
got to get it perfect, tyre centre in the rim. you dont want to be bouncing off the edge of the rim, missing and just not getting the job done. be sure on your angle go for it and be sure you can get it right in there, no messing, job done, done right.
