Tensile Freewheel.
jack0174
Hello.
Today i wanted to get the tensile ffw off my cranks so i got out the shimano bb tool and it seems that the freewheel has screwed on really far
(there onza muscleman cranks btw), so the centre of the cranks covers up the splines on the ffw.
So has anyone got any ideas to get it off?
thanks.
This happend to me, the only way my LBS could get it was with an angle grinder, i didn't need the freewheel, but i asked them if there was anyway they could get it off without breaking it, so they tried, for a good 2 hours and they couldn't, so they just ground it off in the end.
Strip the freewheel down, remove the pawls and springs and get hold of the centre section in a vide with some soft jaws, then stick a pipe over the crank arm and try and undo it.
It might work, hopefully you greased the thread before you screwed it on. :P
