Tartybikes.com
trials-boy
i have just been looking a tarty bikes and some of the bikes on their are unreal.
Does any one have the mose expensive bike on their who go's on this form ??
is it worth the money ??
tell me what you think of tartybikes.com and what bike or parts you got
Thanks
Thanks
:blink:
Its not exactly like no-one on here doesnt know what tartybikes it.
IDK what their most expensive bike is and couldn't give a toss. Tbf
Thanks
This isn't going to get you validated to be perfectually honest this thread is rather pointless.
:blink:
IDK?
tbf?
by the way that is gramaticly incorrect double negative there and im sure you ment is not it
any way this is a pretty pointless thread
as said by jackm this isnt the sort of post that will get you validated
Only 'experts' can ride Koxx bikes (with K-Alone).
So yes, you do get your money's worth with those bikes, but it won't make you a good rider. It will be lighter, making it slightly easier for you to get that bit higher/further, without getting as worn out.
It's pretty much the same with everything - but you have to learn on something, Even if its not even a trials bike.
"- Material: K-ALONE - please read this page, it has important information about the frame"
Jack Chinnery, please, stop commenting on everyone else's typo's, spelling mistakes, punctuation, grammatical errors, the way they use 'text talk', when you can't even get your own posts correct. Yeah, tell them the common rules of getting validated, but don't jump down their god damn throats, seriously.
'trials-boy' - If you want to get validated then look at this.
Tarty are brilliant. I've spent way too much with them over the past few years...
With regard to bikes, you get what you pay for (sort of)
Light, Strong, Cheap - choose two.
In my opinion, monty's and koxx's are over-priced, and anything not made from steel is cheating.
I love Tartybikes Im in there all the time when I'm building a bike! They have the best service I've ever seen, there always happy to help you in whatever way they can no matter how silly the question or how obvious the answer.
I have 3 trials bikes a Echo Lite DD, Czar DD and a Onza T-comp 07 (I think) which I'm selling to a mate soon. But Im in the process of building a GU Typhoon 26". :)
Echo Lite DD Frame
Echo 7075 cranks
Revell rims
Monty rear disc hub
Onza sealed disc front
Hope Mono trials 160mm brakes
Zona Zip forks HS33/disc
Try all 108.9 freewheel
Viz logic bars
Echo headset
Onza T-master stem
KHE collapse chain
Maxxis creepy crawler tyres
Czar DD frame
Echo 7075 cranks
Echo lite frames
Echo Sl rims
Echo disc rear hub
Trialtech sport front disc hub
Echo flat bars
Atomz oversized stem
Hope mono trials 160mm brakes
Echo headset
KHE collapse chain
Maxxis Creepy crawler tyres
