Hs33's. Are They Worth It?
Bol Maaaaaaing
I've been thinking about back brakes.
I have duel disks at the moment and it has been causing me to be a bit scared at doing side hops, seeing as I jump up to the disk side.
I get scared because I think that if I dont get my back wheel high enough I will land on my disk and bend and/or snap it.
If I got a Hs33 then I would get the fame, instead of the disk.
I just want to know if when you have a Hs33 and your wheel is buckled do they lose power or end up being a disadvantage over disks?
What should I do?
Thanks guys
Definately get HS33's.
They are cheaper than disks, they don't brake as easy, they are soooo simple to set-up, you don't have to worry about bending them when sidehopping.
And they give a nice loud noise so you know they are always holding.:P
Yes grinding does weaken the rim, but most people tend to replace the rim before it gets too weak anyway.
Ive run double disc on many frames, 20" and 26" street and natural, and I've never hit a rotor once, and I sidehop to the disc side as well. If you are worried about it, try riding normally for a while first, then if you find you have bent/broken a rotor reasily, then try an HS33. Theres no point spending out for something that may never happen.
A cheaper approach would be to alter your sidehop technique. Unless your hopping onto a rail there's actually no need to land perfectly parallel. Put more angle on the landing then you won't slip onto the chainstay and/ or disk.
But with the Hs33, Do you have to replace the rim very often from grinding?
Sounds like it would be bad on the rim, grinding it.
i think that grinding it wont effect it irs only untill your 6th-8th that really will weaken it that much and as said above hundreds? of riders ride with ground rims so we all can not be that wrong
