Replacing Denguras
sobek
ok so its gotten to the point where im fed up with the denguras...have to bleed it after every 2 or 3 rides and has no power in it anymore.
thing is...shall i replace them with just a magura lever or shall i replace the whole brake system?
echo brake levers are good, the problems with those brakes are the slave cylinder, if you can get some magura slave cylinders and it should work fine
i think
good luck
pablo
er, its normally always the levers that leak....
so change that and it should be fine (Y)
yeh ive noticed thats the area it leaks the most. but i never noticed it to leak a great deal (doesnt seem to leak enough oil to need to be bled again..but i dont know), so im wondering if its leaking somewhere else.
but i read (on pinkbike i think) that the slave cylinders from maguras are stronger than the echos.
would it be worth buying the complete set, including the slave cylinders, or should i just stick with getting a new lever?
I say, just get a Magura, Its tried and tested (Y)
Considering that. Never had a problem with the Maguras on my old mod, even after a year and not being bled at all, they were still doing their job.
Unfortunately...Maguras here are alot more expensive for me. The 2009 apparently cost 950 RMB (95 pounds). Of course i can afford it and will still buy them because...I need them. Just wish Magura had a factory in China so they could be cheaper for me ^^
