Wheel Not Sitting Properly.
Connor Powell
Alright guys,
I've got a new frame, mbk t1000 (blue) But when i put my rear wheel in, in sits way too far right and is sat against the frame? Its a pro2 hub, il have to get a picture tomo probably but if anyone can shed some light on why it may be doing it?
Thanks, connor.
Frames are made differently, basicly you need to bolt the wheel up in the dropouts loosen the spokes on the right hand and tighten them on the left to bring the rim across to the centre.
then when you get close put your brake on and true it between your pads making sure it doesnt rub
You shouldn't have to dish a wheel with a pro2 though. Surely it should sit just dead staight......? I personally wouldn't have touched the wheel without checking the frame. I thought the whole point of the pro2 was to be able to have a central wheel therefore increasing strength etc........
