crispyboy Posted April 23, 2009 Report Share Posted April 23, 2009 Hello everyone i have a problem with my maguraSo when i pull the lever in it goes half way then just wont go anymoreIts not that the pads are close to the rim as the lever feels like metal to metal I have bled it 2 twice any after a while it does it again help please! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted April 23, 2009 Report Share Posted April 23, 2009 its bottoming out, add more fluid cos it is not bled right, did you wind the tpa off when you bled it? Quote Link to comment Share on other sites More sharing options...
crispyboy Posted April 23, 2009 Author Report Share Posted April 23, 2009 its bottoming out, add more fluid cos it is not bled right, did you wind the tpa off when you bled it?not all the way Quote Link to comment Share on other sites More sharing options...
bigamac Posted April 23, 2009 Report Share Posted April 23, 2009 Wind the TPA right down.And bucket bleed.Should be sorted then. Quote Link to comment Share on other sites More sharing options...
Jordan GU Posted April 23, 2009 Report Share Posted April 23, 2009 Wind the TPA right down.And bucket bleed.Should be sorted then.Or normal bleed lol. Quote Link to comment Share on other sites More sharing options...
