Adaptors
Marcus Brown
Hi i have vee mounts but are buying some hs33 so i understand i need specials mounts is it these im pretty sure they are just i want to get it right so i don't lose money ?
http://www.chainreactioncycles.com/Models.aspx?ModelID=291
Yeah they are the ones. If you are getting your brake from Tarty bikes just ask for Evo mounts for V brakes and they will put the right mounts in for you.
I herd evo mounts make the brake toss. You may as well spend your money on a decent V brake, it will work just as well.
They just need to be set up correctly. My brother has a set of 04s with standard blacks in plastic backings on his XC/Jump/Hack bike and they're stiffer than the rear on his T-Lite, and about the same as on my Kot.
Edited by Muel
