Uh Oh..
Herr.Wolfkatze
Easy gents
I have a hope pro 2 and recently it's started singing it's goodbyes to me with it's own personal touch which sounds alot likc "CRACK! CRACK! CRACK!"
Basically sounds like it's skipping, it's like pushbike exhaust backfire <_<
Is there anything I can do about it?
Ric.
Easy gents
Ric.
Strip it an have a gander inside. Pawl/ spring might be broken or could be a duff bearing
Check for cracks on your hubshell. If not, take the wheel off the bike, and pull the cassette body off by the sprocket. Check for wear, broken parts, gunk and dirt. Give it a clean, order some parts from Tartybikes if you need to, and whacck it all backk together.
Yep, exactly what I was going to say. :)
x
