Sidehoping Techniques
Basicly when I do sidehops I keep the brake on as I do it but is this the same as evryone else does it? im not sure but I think Rick Koekoek lets the brake off and does a sort of pedal kick, sidehop hybrid thing.
thanx
Guy
If your doing it with the brake on you wont be able to kick so doubt you will be able to get very high (unless your verry good), and if your doing it with brake on and not kicking your basicly doing a static ?
Danny :)
right ok thanks. I can do pedal hops about 4 pallets high but for some reason just assumed sidehops were done with the brake always on. I first got suspicious when my rolling pedal got higher than my sidehops :S
well I better start learning the other way then thanks again
Guy
