crispyboy Posted January 9, 2010 Report Share Posted January 9, 2010 Hello everyone ive seen brakes and it says they are Hope mono mini brake would they fit standard forks ? Thanks alot Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted January 9, 2010 Report Share Posted January 9, 2010 Hello everyone ive seen brakes and it says they are Hope mono mini brake would they fit standard forks ? Thanks alot Yes they should Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 9, 2010 Report Share Posted January 9, 2010 Yeah they should do 'Mini' is just the name, they are not literally minuscule sized Quote Link to comment Share on other sites More sharing options...
crispyboy Posted January 9, 2010 Author Report Share Posted January 9, 2010 Yeah they should do 'Mini' is just the name, they are not literally minuscule sized so basically the try-all and hope mono trial brakes ? Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted January 9, 2010 Report Share Posted January 9, 2010 so basically the try-all and hope mono trial brakes ? Yes pretty much, just tryall are usually odd sizes, but these should be fine if used with normal forks such as +0mm etc. So yeah they'll fit. Quote Link to comment Share on other sites More sharing options...
scotty007 Posted January 9, 2010 Report Share Posted January 9, 2010 Yes pretty much, just tryall are usually odd sizes, but these should be fine if used with normal forks such as +0mm etc. So yeah they'll fit. I run the hope mini on a set of echo sl with a 203mm rotor so yes would be the answer in my opinon. Quote Link to comment Share on other sites More sharing options...
