How Much Is My Bike Worth?
I am ze best
Just want to know how much you think I could get for my bike?
Here is the spec:
Zona zip frame
monty disc forks
tryall rage 09 bars
trialtech stem
trialtech foam grips
Magura hs33 rear brake with koxx red pads
front onza/avid disc
cane creek headset
echo sq taper cranks
trialtech caged pedals
v!z sq taper bb
echo tr freewheel
tensile bashring
monty non drilled rear wheel with monty tyre
onza side drilled wheel with tryall tyre
trialtach sprocket
Just a rough guide please!
Edited by I am ze best
Here is the spec:
Zona zip frame
monty disc forks
tryall rage 09 bars
trialtech stem
cane creek headset
v!z sq taper bb
echo tr freewheel
tensile bashring
trialtach sprocket
If you sell up I will kill you using a screwdriver and cut you up with a bread knife! :P
