Help With Choosing Brake Pads!
TrialZonn
16 members have voted
  1. 1. What pads would you buy for your back brake?
    • RockMan Blues
      4
    • HeatSink CNCed
      7
    • TryAll Croco Browns
      3
    • TryAll Croco Reds
      0
    • TryAll Croco Blues
      0
    • TryAll Croco Yellows
      2
    • TryAll Croco Clears
      0
Hello to everyone!
I'm about to buy some brake pads for my rear Magura HS33 brake and I really need your advice and experience.
I'm running a light grind with no tar.
Previously used pads are:Onza Limes, Rockman Greens, Adamant HS33 Pads and Magura Blacks.
So...what set of pads from the above would you buy for using with your rear brake with a light grind?
I'm searching for raw bite, lasting and holding power (modulation really not needed).
Please note why you choose your pads after voting!
Many thanks!
Hello to everyone!
Many thanks!
Tnn (Y)
Heatsink Yellows all the way. The key is to have a sharp grind and you'll get loads of bite. Also, make sure they are set up perfectly square as the cnc backingsare very stiff, this will allow the pads to transfer more braking force. Been running a set for ages now on a sharp medium grind, still got 6+mm of material left. Well worth the money.
