Rounded Brake Mount Bolt
Ashley Sayers
The above methods can work, but a bit much for the job you're after. You run the risk of gashing your frame and other parts when chopping and drilling away.
Molegrip technique is good, and works... but not if the head of the bolt is sunk in like on boosters or some 4 bolt mounts.
Simplest, most fool proof-method: superglue the most rubbish unwanted unloved allen key in your toolbox into the head of the bolt. Let it dry, and it'll have bonded inside the rounded head. Screw it out. It's the most harmless method of all.
