Foot Positions
Woodster
i have a slight problem... i side hop to the right... but my right foot is forwards.
it stops you from tucking properly as your left foot is in the way of where your arse should go...
and i used to catch my foot :/
Then you are doing the side hop wrong. You are ment to go the same way as your front foot so that the foot that is backwards will push you.
I dont know if it makes a difference but i wheelie with my right foot and when im rocking i have my left foot forward.
that is normal.
Edited by Kenny--Trials
That makes no sence.
to do bigger hops, its easiest (note I didn't say better) to go to the side of your back foot, that IS the normal way to do it.
If you are wanting to ride bmxy with spins and shiz, the it may be best to sidehop towards your front foot as it will help with the natural direction in spins depending on what moves you are doing.
  • Like 1
