Echo Urban 24"
Andrew C
Right so basically i just bought a echo 24" of here so i decided i would buy the trialtech sprung tensioner as the tensioner that was on it was abit naff.
So anyway when it came to putting it on i noticed that the hub has quick releases on it so this means the hub doesnt take 8mm bolts. This is where the problem lies the trialtech tensioner bolts on to the hub and has an 8mm bolt so my question is, is there anyway to attach the tensioner withought bolting it to the hub.?
Edited by Andrew C
That is the tidiest chain tensioner I have ever seen. Hopefully i'll get mine close when it arrives.
it looks good with the alignment pin cut down(silver rod to get chain alignment),it sticks out heaps far.
make did you ever hit it on the 24? with your ankles etc.
I didn't give it a chance - cut it down before my bike left the workstand when I first put the tensioner on :)
