Wheel Alignment
Little Yoshi
if you can pull it off then run no chain tensioners and just slam the wheel all the way in. Its a guaranteed way of never having any mechanic problems with your rear wheel ever. getting the chain the exact right tension can be hard though, but if you are not too picky about gear ratio it can be done easier. Or just do what adam said its a lot easier. Only bonus of slamming is you save a couple grams cause you don't need tensioenrs
Edited by sayshell
