Echo 24" Mrk 1 V 2
AkuskaUK
Pretty much the same frame essentially.
2010/11/12
Wheelbase: 1065mm
Chainstay Length (Using 18:14 ratio): 360mm
BB Rise: 70mm
Head Angle: 72 degrees
Centre of BB shell to top centre of head tube: 655mm
Weight: 1.492kg (Without BB), 1.752kg (With steel BB).
2013
Wheelbase: 1055mm
BB Rise: 70mm
Centre of BB shell to top centre of head tube: 650mm
Weight: 1.436kg (Without BB), 1.778kg (With steel BB).
The 2013 is ever so slightly heavier apparently and 10mm shorter, has 135mm spacing and the black finish. Strength should be no issue.
Edit:
How can the 2013 be lighter than the Mk1 when weighed without the BB, but when installed with the bb, which is the same in the two frames, be slightly heavier? ...
Edited by Echo Lite 09
