Disc brake tab help
CurtisRider
I am going to weld on a front disc tab to my Pashley forks and I have drawn up a quick 2D design file ready to laser cut an acrylic model to test it all fits before getting it cut properly.
Does this sort of design look ok? I have been looking at other disc tabs and this seems to be a pretty common shape, the only difference I have noticed is some have a cut out inbetween the mounting holes where it attaches to the fork...reducing the area for weld which I think I will avoid seeing as it is such a high streess area. The top section presumably is to disperse some stress up the leg, I know tuning forks had this and cracked there so i'm not sure whether to stick with it or not?
