Pads in a mono trial
will ackerley
I had the exact same thing other day, got a allen key roughly same size as the pin and pressed real hard till it came out - took some effort. Put it back in without the rubber ring and left the small clip in to retain, still retains the pads.
Some advice I read was to squirt some lubricant into the pin and let it soak a few minutes then try again, but chances are some will get onto your pads so only do this if pads will be replaced.
