Hope mono trial pad rock?
jnthebiker
Hey all. My hope mono trial front brake feels good and stops well, but when I hold the lever and move the bike forwards and backwards, the front wheel and rotor turn a little bit even though the pads are locked. Is this pad rock? What should I do?
Thanks,
JN
^ i done that with mine and worked perfectly.
instead of plasters i used about 4 layers of selotape on each pad, works a treat :) be sure to put tape on the retention pin too! even if its a bit hard to push into the caliper, just make sure the visible part of the pin, when its in the calliper, has tape on it. i used 2 layers and again, worked fine :)
