How Do I Overclock My Processor?
Johneh
1. Ask yourself *WHY* do you want to overclock?
2. Do you understand the performance gains which you *may* recieve?
3. Do you have high quality hardware, which will be capable of running at faster-than-spec speeds?
4. Do you have sufficient cooling to cool said componants? (I've got WATER flowing around my computer, as air wasn't sufficient!)
Before you do ANYTHING - read. Read. Read!
Check Google.
www.overclockers.com
www.bit-tech.net
www.ocuk.com
www.extremeoverclocking.com
Loads of others, too many to mention.
It's probably wrong, saying that it's 34*C.  You have to alter the settings in the BIOS, and unless you know what you're doing, it's probably not worth you trying...
It might be a misconfiguration of MBM5.
MBM5 switches round the System Temp and CPU Temp by default on my motherboard..... which is annoying (N)
