Hope Closed Pro Lever
Da Make
You need a pair of small internal circlip pliers, some goggles, and a bit of patience!
Disconnect the hose from the lever (be careful of Dot fluid spillage), remove the lever blade, to leave the push rod sticking out of the lever. Pull the black dust seal off, to reveal the circlip and brass washer.
The circlip will come out with a bit of effort, and the piston will pop out along with the spring.
Then, just work backwards, and re-bleed - job done (Y)
Actually I want to replace the cylinder, NOT piston! The cylinder some how has scrathes inside and that rips the seals of piston...
