Few Questions
sir trial a lot
hi,
how often do you strip your bike right down to the frame to clean it and regrease hubs etc. plus do you find unsealed hubs get full of rubbish very quickly? as i live at the coast we practice on the old buildings at the beach = a lot of sand :( it gets everywhere and i cant seem to find anything to keep it out :) apart from getting sealed hubs etc. which i will when i have the money, what can i do to protect my bearings for the time being? (i am aware there may be nothing)
I strip it down when I have a new frame... so not very often.
Everything I run now runs on sealed bearings so that's not much help to you.
Other than cleaning/re-greasing the hub often... You could add a 'grease port' to the hub - drill a small hole in the hub shell and then use a syringe to pump grease into it. The old grease should come out where the bearings aren't sealed. Hopefully along with any crap that's got in.
Otherwise keep saving :(
Jon
john,to protect, your hubs get a bit of inner tube and cable tie it around the hub. :lol: you going to bring ur monty to a trial some time? to have a bit muck about before it starts? :D"
