Flash Help Needed
Todge
Ok, refurbishing the website and I have hit a hurdle.
How do I make a section of the page which includes text and pictures scroll down. I know Jonny has done it before previously, but cannot find any tutorials on it anywhere :P
Cheers
Todge
If you use Flash MX, its piss easy.
Make a text box, and make it Dynamic, not static, this can be done in the options. Type in the stuff. Now drag across the scroll bar entity from the right, and using the top left corner, move it to the right side of the text area, and you will see it attach. Name the text box, then point the scroll bar to the name.
That should work. If not, theres a tuturial actually in flash somewhere.
If you don't use MX, good f**king luck :P
Cheers ddue.
Its worked, however the text carries on beyond the bottom of the page :P
You need to resize the text box.
Bottom right, there will be a square filled black box, i think. You need to change it to a circle one. However, this is the part i always forget. :P
Fiddle around, its there somewhere :)
